It would be where the air cleaner hooks up to the motor, where the accelerator cables go have someone push on the gas petal and watch for movement, thats where you throttle plates will be
OK. I tried to squirt some cleaner in there. I removed the hose and did my best to squirt it on the plate inside, both while it was open and again while it was closed. It was a little difficult as it is horizontal. I got cleaner everywhere so I will wait for it to dry up a bit, then I will put it all back together and pour some water on the engine as I am afraid of engine fires with that cleaner being so flamable. Also, found that stupid valve and it was 'anti-freeze" green inside so I poured some cleaner in that too and let it hang in an attempt to clean that as well.
Thursday, May 1st, 2008 AT 8:06 PM
