I am not too clear with your description. Are you saying that the engine cranks but not starting/catching, or it doesn't even try to crank. If it cranks but not catching, did it even try to catch?
You said distributor checked not cracked, did you check the inside rotor, making sure the tip of the rotor is not worn out?
SPONSORED LINKS
Thursday, January 22nd, 2009 AT 3:23 AM
