Brakes problem
1997 Nissan Sentra 6 cyl Two Wheel Drive Automatic alot miles
when I turn my head lights on my break light on the right side will go out
Sunday, October 24th, 2010 AT 9:56 AM
BLUELIGHTNIN6
MECHANIC
This is an indicator of wiring issue, most likely ground wire. Check the wiring at all light assemblies (both front headlamps, both rear taillamps) if all wiring looks good there then check wiring at the headlight switch
