***There is a short-circuit in your multi-function switch***
***Replace your left headlamp. The low beam is good, but your high beam is burned out. Bulb 9003. While you are at that, check the wiring harness for both sides, make sure that they are not frayed or burned.***
***Your e-brake also powers through the multi-function switch***
SPONSORED LINKS
Tuesday, February 24th, 2009 AT 4:16 AM
