[quote:9fa9d8a7be="Bruce Hunt"]The sensor on the tranny sends the signal to the speedometer, odometer, and tach. Failure of one of the these is the wiring but most likely the item itself. If they all fail then you look to the sensor.[/quote:9fa9d8a7be]
Thank you for your response. Only the speedometer and the odometer not working (They work on and off, tho not working most of the time. When they are functionsing and not functioning at the same time. I mean when one works, other one works. When one doesn't work, other one doesn't work either).
The RPM, engine tempurater and Oil guage works fine.
So most likely, do u think i need to change a new cluster?
I have another question. When I change it with an used cluster, because it is impossible to find a similar millage on the odometer, is it possible for the mechanic to ajust the milliage on the odometer?
If so, how is it done?
thank you
Oct 20, 2006 at 8:03 AM
