1991 Sentra SE-R Starts Intermitantly
DEMON_MONGOOSE
  • 1991 NISSAN SENTRA
My Nissan does not start consistently. At times it fires right up, and others I can turn the key for 20 minutes without any luck.
When I turn the ignition on for the most part nothing happens, no cranking, no starter whine, nothing. Its as though I didn't try. At other times, I hear a loud click yet nothing still happens. Then out of the blue it will start.
Lights, radio and accessories work fine. I must get this fixed. Please help
Wednesday, August 29th, 2007 AT 1:03 AM
Sounds like the ignition switch went bye-bye. When you turn key to run position do you see the alternator and oil light on the dash.
Wednesday, August 29th, 2007 AT 3:19 AM
