1992 Nissan Sentra can't get car to start
DAQUIRI
  • 1992 NISSAN SENTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 163,000 MILES
I just bought a used 92 nissan sentra and it had a new battery but the alternator went out. I replaced it and it still won't start. I can push start it and then she runs fine, but all she does is click and try to start. What else could be wrong?
Wednesday, December 19th, 2007 AT 2:13 PM
Is the new alternator putting out and reconditioning the battery if so do below
Hold key to start position -find the black and white wire at the starter solenoid look for power-power there tap the starter if it kicks over-the starter is bad-if no power. Find the clutch interlock switch at the kick panel on the connector you will see a brown and white and a plain black jump this two together and attempt ot start-if it starts the switch is bad. If not find the clutch interlock relay at relay box left front of engine compartment look for power at black and white-no power the igniton switch is faulty-if power is there the relay is bad.
Wednesday, December 19th, 2007 AT 2:21 PM
