1987 Nissan Sentra stalls, then won't start
TREGUSH
I have a 1987 Nissan Sentra with 252,000 kms that ONLY stalls in the drive-thru. When I have my foot on the brake and am slowly creeping forward, it will stall and then it will not start for another hour or two. I have replaced the coil, and the module which come together as well as some ground wires. This has still not fixed the problem. Any suggestions would help!!!
Apr 13, 2007 at 1:00 PM
  • 75,988 POSTS
[quote:74c1c0b150="tregush"]I have a 1987 Nissan Sentra with 252,000 kms that ONLY stalls in the drive-thru. When I have my foot on the brake and am slowly creeping forward, it will stall and then it will not start for another hour or two. I have replaced the coil, and the module which come together as well as some ground wires. This has still not fixed the problem. Any suggestions would help!!![/quote:74c1c0b150]
Sounds like the fuel pump is failing BTDT with a 94 sentra-check the fuel pressure-
To get to the pump you have to remove the back seat
Apr 13, 2007 at 3:45 PM
