2005 Nissan Pathfinder U1000 Code
AJBEPS
  • 6 POSTS
I have a 2005 Nissan Pathfinder SE and my engine service light is now turned on. I went to my a good friend who has a dtc machine and he stated that the dtc code is a u1000. Is this something that is under warranty and is this a big project?
Thank you,
AJ
Feb 6, 2007 at 6:35 AM
SERVICE WRITER
  • 9,123 POSTS
It has to do with the Controller area network (CAN) Communication line not making a connection with other module(s). It means one of the computers is not talking to the network. Two of the most like scenarios is a blow fuse or a bad computer. I would try checking all of the fuses, here is a guide and diagrams to help us get it fixed.
There is an ECM relay that could have gone out as well. There are many fuses that run the CAN so make sure you check them all with the key on.
and
Check the diagrams below.
If all checks okay try a used ECM and plug it in.
Cheers
Feb 6, 2007 at 10:05 AM
  • 75,988 POSTS
Since model year 2003, a growing number of domestic and import vehicles have been built with a new onboard communications protocol called CAN (Controller Area Network). CAN is essentially an engineering standard for how computers and modules talk to one another via the serial data bus in a vehicle's wiring system. It's a high speed standard designed for powertrain control modules, antilock brakes and stability control systems.
Feb 6, 2007 at 8:31 PM
SERVICE WRITER
  • 9,123 POSTS
Your right Ras.
It really is astounding how the complexity has changed the last 30 years, not to mention the difficulty of getting information not to mention the correct information on these things.
Manufactures have to allow access to the information they have by law. As I understand it, bad information is released too. It is updated at a later time through a TSB.
Feb 6, 2007 at 9:08 PM
  • 75,988 POSTS
Thank you for the guides and instructions, I did some testing and found the computer was bad, I got a used one and plugged it in. Car runs great! thanks you guys.
Feb 6, 2007 at 10:27 PM
ODDY
I have this Nissan premera 2005 it's jerking when steaming or on standby
Sep 8, 2017 at 3:06 AM
  • 55,721 POSTS
Please post your question here
Cheers, Ken
Sep 9, 2017 at 9:59 AM
Suggested Repair
Check all CAN-related fuses with the key on and test the ECM relay. If those are good, replace the ECM; a used ECM resolved the U1000 code in this case.
Conversation Summary
A 2005 Nissan Pathfinder SE had an engine service light with DTC U1000, a CAN communication fault meaning a module is not talking on the network. Experts advised checking all related fuses and the ECM relay, then trying a used ECM if those tests passed. The owner found the computer was bad, installed a used one, and the vehicle ran normally. A separate Primera question was redirected to a new post.
