1994 Nissan Pathfinder Failed Emissions
DONNIE SKAGGS
I have a 94 Pathfinder 4wd LE with 152,000 miles. Six months ago it passed emissions with flying colors. Yesterday I tested it and the numbers are
HC 3086
CO12.76
CO2 4.85
It also just started idling rough.
Can you help?
Thanks
Dec 5, 2006 at 6:22 AM
2CARPRO JACK
  • 11,533 POSTS
Has it been tuned up recently?Sounds and looks like the engine has developed a miss.It will never pass emissions unless its firing on all cylinders. You can tune it up yourself if your mechanically inclined at all.Just use OEM quality parts
Dec 5, 2006 at 7:09 AM
Suggested Repair
Perform a tune-up with OEM-quality parts and correct the cylinder misfire so the engine fires on all cylinders before retesting emissions.
Conversation Summary
The owner of a 1994 Nissan Pathfinder with 152,000 miles reported a sudden emissions failure with very high HC and CO, low CO2, and a new rough idle after passing six months earlier. The expert said this indicates a misfire and that the vehicle will not pass until it fires on all cylinders, recommending a tune-up with OEM-quality parts.
