1991 Nissan Pathfinder Crankshaft Spins
NELDOR
I am trying to remove the water pump but the cranshaft keeps spining. How do I stop it from spinning
Nov 25, 2006 at 4:25 AM
BACKYARDMECHANIC
  • 337 POSTS
I'am guessing you are trying to get the center bolt from the crank shaft out. I'am also guess you don't have access to air tools for this would be the easiest way to remove it. If you have a flywheel wrench you can have and assistant hold the flywheel while you remove the bolt. Also if the car is a stick you can leave the car in gear and this will also prevent the motor from spinning while removing the bolt. However if you are referring to the fan bolts leave the fan belt in place to pervent the fan from spinning while removing the bolts
Hope this helps. BYM :?
Nov 25, 2006 at 10:42 AM
Suggested Repair
To stop the crankshaft while removing the center bolt, use an air tool if available. Otherwise, have an assistant hold the flywheel with a flywheel wrench, or leave a manual transmission in gear. If the fan bolts are the issue, leave the fan belt in place so the fan cannot spin.
Conversation Summary
The owner of a 1991 Nissan Pathfinder could not remove the water pump because the crankshaft kept spinning. The expert assumed the center crankshaft bolt was the problem and suggested air tools, holding the flywheel with a wrench and an assistant, or leaving a manual transmission in gear. If the fan bolts were the issue, the fan belt should be left in place.
