2005 Nissan Pathfinder
CONNMAN530
  • 2005 NISSAN PATHFINDER
Engine Mechanical problem
2005 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
My car has 85000 miles on it. Occasionaly when the car has been parked on an incleine for a few hours or more engine will crank but not start right away. What do you think this is? Should I le this develope o should I repair immediately.
Tuesday, March 3rd, 2009 AT 9:04 PM
  • 31,937 POSTS
Hi there,
Just try this simple test, when starting, first listen for the fuel pump to run, you may or may not hear it, but let the ignition sit in the on position for a few seconds before cranking, see if this helps if so, you may be getting fuel drain back and you don't have enough fuel pressure for start up, letting the pump run first will boost fuel pressure, try this first.
Mark (mhpautos)
Wednesday, March 4th, 2009 AT 2:42 AM
