1994 Nissan Pathfinder Fuel
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BMAT1959
I replaced 3 fuel injectors and had the other 3 cleaned. After putting the car back together, it started right up and i ran it around the block a few times. It ran great. I went to use the car about an hour later and it almost didn't start. When it did start it was only hitting on 2 or 3 cylinders.
I replace five of the six spark plugs (the almose new spark plugs were all foulded) and the engine started right up but started runnin rough right away. A lot of white smoke was coming from the exhause and i believe gas was dripping from the tail pipe.
any ideas on what should be done now. I am not a mechanic.
Jan 17, 2009 at 8:27 AM
  • 75,988 POSTS
White smoke coming out the exhaust if its not condensation -then your burning coolant in the combustion chamber-Do a compression check and get back with me-Posssible blown headgasket/cracked head or block
Are you overheating? temp. gauge acting weird
Jan 17, 2009 at 8:33 AM
