1990 Nissan Pathfinder dirty seat around the spark plug
AASTE
  • 1990 NISSAN PATHFINDER
Electrical problem
1990 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
When I removed my spark plugs I notices dirt deposit around the seat. It possible prevents the plug seal work perfectly. How do I remove the dirt from 12" hole without dumping it on the pistons? Or, does it matter if it is there?
Sunday, October 17th, 2010 AT 10:47 AM
Hi aaste, Welcome to 2carpros and TY for the donation
Use a coat hanger/welding rod and solvent scrape it as much as you can around the plug seat-now loosen all the plugs about 2 turns out-disable the coil and crank engine over for atleast 10secs, this will blow it out. If there's no metallic debris and it does fall in, it will just burn off-
Monday, October 18th, 2010 AT 3:55 AM
