1992 pathfinder
NOAHNEVIL
nissan pathfinder 1992 165000 v6
it wont start if you sometimes move the 4x4 shifter it is a automatic .it will start but now it wont .please help if you can.runs good when it will start.i checked all the fuses there all good.
Nov 27, 2007 at 5:12 AM
FISHERMAN
  • 937 POSTS
[quote:3a2b66e50e="noahnevil"]nissan pathfinder 1992 165000 v6
it wont start if you sometimes move the 4x4 shifter it is a automatic .it will start but now it wont .please help if you can.runs good when it will start.i checked all the fuses there all good.[/quote:3a2b66e50e]
Hello !!
It`s not cranking?
check the neutral switch for the 4x4..
(could be loose or bad)
good luck!
Nov 27, 2007 at 5:22 AM
FISHERMAN
  • 937 POSTS
[quote:1e478fa63c="fisherman"][quote:1e478fa63c="noahnevil"]nissan pathfinder 1992 165000 v6
it wont start if you sometimes move the 4x4 shifter it is a automatic .it will start but now it wont .please help if you can.runs good when it will start.i checked all the fuses there all good.[/quote:1e478fa63c]
Hello !!
It`s not cranking?
good luck![/quote:1e478fa63c]
Hello !!
I received your PM and I checked where are the switch and found that they are two switches that can "cut" the starter those switches are:
1: the inhibitor switch (a/t) which its located on right side of the transmission
And 2: transfer switch (4wd) which is also located on right side of the transmission..
check both of them and see if they are "closed".
let us know and good luck!
Nov 27, 2007 at 12:43 PM
