1981 Datsun 280ZX Heater Fan Dead
NISSAN
ELIAS_RUSSELL
My car is a 1981 Datsun 280ZX Turbo, 80,000 miles and has a L28 Motor in it. The problem I'm having is with the fan. I made a trip about sixty miles away and back and the heater was working fine, as it always has. I parked it, but when I got in the car the next morning to heat it up before work, the fan didn't come on. Not only did it not come on, but it hasn't come on since then. I'm not sure if it's the blower motor or not, so I'm hoping you guys can help me out, but if it is...where is it located at? I just need to know so I can give it the 12v test. Thanks
Feb 4, 2007 at 3:51 PM
  • 75,988 POSTS
[quote:544d88792a="elias_russell"]My car is a 1981 Datsun 280ZX Turbo, 80,000 miles and has a L28 Motor in it. The problem I'm having is with the fan. I made a trip about sixty miles away and back and the heater was working fine, as it always has. I parked it, but when I got in the car the next morning to heat it up before work, the fan didn't come on. Not only did it not come on, but it hasn't come on since then. I'm not sure if it's the blower motor or not, so I'm hoping you guys can help me out, but if it is...where is it located at? I just need to know so I can give it the 12v test. Thanks[/quote:544d88792a]
Normally the blower motor is on the pax side behind the glove box hidden.
Might be the control switch,fuse/relay,resistor pack and motor. If it was me I'll start at the motor with test lead to hot start it-then go from there.
Feb 4, 2007 at 11:35 PM
Suggested Repair
The blower motor is normally on the passenger side, hidden behind the glove box. Possible causes include the control switch, fuse or relay, resistor pack, and the motor itself. Start by applying power directly to the motor with a test lead, then continue diagnosis from there.
Conversation Summary
The owner of a 1981 Datsun 280ZX Turbo with an L28 engine and about 80,000 miles says the heater fan worked normally on a round trip, then failed to come on the next morning and has not worked since. They want the blower motor location so they can apply a 12-volt test. The expert says the motor is typically behind the glove box on the passenger side and that the switch, fuse or relay, resistor pack, and motor should be considered, starting with a direct power test at the motor.
