1981 Datsun 280ZX Heater Fan Dead
Normally the blower motor is on the pax side behind the glove box hidden.
Might be the control switch,fuse/relay,resistor pack and motor. If it was me I'll start at the motor with test lead to hot start it-then go from there.
Suggested Repair
The blower motor is normally on the passenger side, hidden behind the glove box. Possible causes include the control switch, fuse or relay, resistor pack, and the motor itself. Start by applying power directly to the motor with a test lead, then continue diagnosis from there.
Conversation Summary
The owner of a 1981 Datsun 280ZX Turbo with an L28 engine and about 80,000 miles says the heater fan worked normally on a round trip, then failed to come on the next morning and has not worked since. They want the blower motor location so they can apply a 12-volt test. The expert says the motor is typically behind the glove box on the passenger side and that the switch, fuse or relay, resistor pack, and motor should be considered, starting with a direct power test at the motor.
