1991 Nissan Maxima CV Boot Split
MMKK007
1991 Nissan Maxima, GXE, 100K miles.
I have 2 questions:
1. What would be the cost of a power steering pump (parts+labor)?
2. My car's CV joint rubber seals were found opened up. And I am guessing it must be like that for quite some time now. What needs to be replaced now? Any cost estimates?
Thanks
MM
Mar 21, 2007 at 7:38 AM
BOOTDOG
  • 665 POSTS
1. it's hard to give estimates due to different shops in different localities are gonna have different estimates. you'll need to call a few shops around your local area for any estimates.
2. if the cv boot is split, the best way to fix it is to replace the whole axle. i know that axles are not that expensive and are pretty easy to do. having the boot split open allows dirt to get inside the joint causing damage in the long run. so i wouldn't recommend just the boot replacement. it's a lot more work involved too.
Mar 21, 2007 at 10:00 AM
Suggested Repair
Call local shops for power steering pump parts-and-labor estimates, since prices vary by area. If a CV boot is split, replace the whole axle rather than only the boot so dirt does not damage the joint.
Conversation Summary
The owner of a 1991 Nissan Maxima GXE asked for power steering pump cost estimates and what to replace after CV joint boots were found split open. The expert said pump prices vary by shop and locality, so local quotes are needed. For a split CV boot, the expert recommended replacing the entire axle rather than only the boot, noting axles are relatively inexpensive and easier than a boot-only repair, and that an open boot lets dirt damage the joint.
