1997 Nissan Maxima Rubber Boots
MIKEREG
1997 Nissan maxima 120,000kms.
The rubber boots need replacing - should axle be done too?
Jan 20, 2007 at 12:48 PM
SERVICE WRITER
  • 9,123 POSTS
How long have they been opened?
If a few weeks, you might be okay...
It may not be much more to get replace that axle shafts.
Jan 20, 2007 at 1:56 PM
MIKEREG
They have been like that for a few years, so I guess the axle too?
Jan 20, 2007 at 2:41 PM
SERVICE WRITER
  • 9,123 POSTS
Yeah, I would say. Couple options for you if money is tight. Get a couple from the junkyard. Genrally, the worse that happens is when they finally give out is that you are stranded. So if you can live with that, wait until they go. Typically they start making noises first.
Jan 21, 2007 at 12:05 AM
Suggested Repair
Because the rubber boots have been open for years, replace the axle shafts rather than only the boots. Remanufactured or junkyard axles are options if the budget is tight. Waiting risks being stranded when they fail, though noise often starts first.
Conversation Summary
The owner of a 1997 Nissan Maxima with 120,000 km asked whether the axles should be replaced along with torn rubber boots. After learning the boots had been open for a few years, the expert recommended replacing the axle shafts. Junkyard axles were suggested as a lower-cost option, while waiting was described as a risk of eventually being stranded, usually after noise develops.
