2001 Nissan Maxima Weak A/C, Brake Shake
RPRABHUATTUR
I bought 2001 nissan maxima 2 months back. Never used A/C so far, when I was using A/c last 2 weeks back. I don;t see A/c is working very well, just normal comes out. But heater work very well. Any thought what needs to be checked ?
Also, when I drive in Down and apply brake steering shakes little ?
Any suggestions would be greatly appreciated
Thanks,
Prabhu
Mar 11, 2006 at 1:04 PM
FISHERMAN
  • 937 POSTS
have it check the a/c gas.. probably needs a refill (also check for leaks)
the "shake" it can be caused for a damaged brake disc..
have your brakes checked too.
Mar 11, 2006 at 2:13 PM
RPRABHUATTUR
Thanks and appreciate your response...
Prabhu
Mar 11, 2006 at 2:33 PM
Suggested Repair
Have the A/C refrigerant level checked and look for leaks; refill if low. Also have the brakes inspected for a damaged brake disc that can cause steering shake when braking.
Conversation Summary
The owner of a 2001 Nissan Maxima reports weak A/C cooling while the heater works well, plus slight steering shake when braking. The expert recommends checking A/C refrigerant and leaks, and inspecting the brakes for a damaged disc.
