2001 Nissan Maxima Right Front Grinding
BLUNT
I have a 2001 5 spd nissan maxima with 91,000 miles on it. When I attempt to turn left the right front assembly sounds as though I have metal on metal rubbing. As I take off slowly I also hear a grinding sound from the same right front tire. Can someone give me some advice prior to taking it to the dealer and getting violated in labor charges?
Sep 2, 2006 at 12:17 PM
SYNCRAIT
  • 235 POSTS
i would suggest removing the wheel that is the problem and checking the dust guard for the brakes it is on the back side of the rotor and on occasion it gets bent and will start rubbing on the rotor making a grinding noise.....good luck :)
Sep 2, 2006 at 11:21 PM
Suggested Repair
Remove the right front wheel and inspect the brake dust shield on the back of the rotor. A bent shield can rub the rotor and cause grinding; straighten or replace it if it is contacting the rotor.
Conversation Summary
The owner of a 2001 Nissan Maxima with 91,000 miles reported metal-on-metal rubbing when turning left and grinding from the right front tire when pulling away slowly. The expert advised removing that wheel and checking the brake dust shield behind the rotor, which can bend and rub the rotor.
