1999 Nissan Maxima Belt Squeal on Startup
65RJT
Nissan Maxima SE-1999 75K Miles
Recently had some worn belts replaced. Upon startup soon after a 2-3 second squeal occurs about 80% of the time when starting.
Brought it back they fixed it by spraying the belts and it was fine for the day, but next morning back again.
thoughts?
Jan 3, 2007 at 6:05 AM
BACKYARDMECHANIC
  • 337 POSTS
Belts may need to be adjusted.
Jan 3, 2007 at 10:52 AM
65RJT
If they need adjusting and only do it on startup why would spray fix it for the day?
PS brought it back in they said it did not need adjusting..
So I will need more ammoto get them to properly adjust if that is the case.
thanks
Jan 3, 2007 at 11:20 AM
SERVICE WRITER
  • 9,123 POSTS
Backyard mechanic is still likley right. The motor has a belt tensioner that automatically keeps the tension. It's probably weak.
You can try replacing just the belt, but fair chance of the tensioner being responsible.
I'm pretty sure that year has a spriong loaded tensioner. If they are v-belts, then I am wrong.
Jan 3, 2007 at 11:29 AM
Suggested Repair
Inspect the automatic spring-loaded belt tensioner, which is likely weak, and replace it if it does not hold proper tension. Replacing the belt alone may help, but the tensioner is the more likely cause; belt dressing only quiets the squeal temporarily.
Conversation Summary
A 1999 Nissan Maxima developed a brief belt squeal on most startups after worn belts were replaced. Belt spray stopped it for one day, and the shop said adjustment was not needed. Experts said the automatic spring-loaded tensioner is likely weak and should be checked, with belt replacement as a less certain option.
