1987 Maxima Alternator Belt
1987 ALL OTHER MAKES ALL OTHER MODELS
STEWARTTL
I need instructions on changing my alternator belt. Please help. I cannot get the car to move to take it anywhere. I am on my own. Any advice would help.
Jan 23, 2006 at 2:25 AM
FISHERMAN
  • 937 POSTS
I dont think its a big deal to do it!
don`t worry!
first at all, check your car`s hood for the route of the belt (it should be somewhere printed in there)
after that look for a tensioner and a free roller, I don`t know what kind of tensioner use your car, spring loaded or adjustable (screws) loose the tensioner install the belt and adjust the pressure (if its spring tensioner dont worry about it) that simple!
post your questions!
Hope it helps!
Manuel.
Jan 24, 2006 at 12:55 AM
Suggested Repair
Check the belt-routing diagram under the hood, locate the tensioner and idler roller, loosen the tensioner, install the alternator belt on the printed route, and set belt pressure if the tensioner is screw-adjustable. If it is spring-loaded, tension is applied automatically.
Conversation Summary
The owner of a 1987 Maxima asked for help replacing the alternator belt because the car could not be driven for service. The expert said the job is straightforward: follow the hood diagram, release the tensioner, fit the belt, and adjust tension unless the tensioner is spring-loaded. The expert did not identify which tensioner this car uses and invited follow-up questions.
