A rattle like noise
DIGITAL
04 Maxima SL 3.5 35,000 miles.
I've noticed that when I accelerate and the rpm needle is between 2 and 3000 it makes a funny rattle noise. Any idea what that could be?
Jul 18, 2007 at 7:49 AM
  • 75,988 POSTS
[quote:7ef657c758="digital"]04 Maxima SL 3.5 35,000 miles.
I've noticed that when I accelerate and the rpm needle is between 2 and 3000 it makes a funny rattle noise. Any idea what that could be?[/quote:7ef657c758]
Could be a spark knock also called detonation-problem areas: Inop. EGR, Low octane fuel,Too Advance, Overheating, Knock sensor.
Jul 18, 2007 at 7:12 PM
DIGITAL
[quote:05b679c0dc="rasmataz"][quote:05b679c0dc="digital"]04 Maxima SL 3.5 35,000 miles.
I've noticed that when I accelerate and the rpm needle is between 2 and 3000 it makes a funny rattle noise. Any idea what that could be?[/quote:05b679c0dc]
Could be a spark knock also called detonation-problem areas: Inop. EGR, Low octane fuel,Too Advance, Overheating, Knock sensor.[/quote:05b679c0dc]
Thanx for the reply. If its due to low octane can it be solved by using a higher octane gas? or do I have to get something done.
Jul 19, 2007 at 4:16 AM
  • 75,988 POSTS
[quote:738fcf643a="digital"][quote:738fcf643a="rasmataz"][quote:738fcf643a="digital"]04 Maxima SL 3.5 35,000 miles.
I've noticed that when I accelerate and the rpm needle is between 2 and 3000 it makes a funny rattle noise. Any idea what that could be?[/quote:738fcf643a]
Could be a spark knock also called detonation-problem areas: Inop. EGR, Low octane fuel,Too Advance, Overheating, Knock sensor.[/quote:738fcf643a]
Thanx for the reply. If its due to low octane can it be solved by using a higher octane gas? or do I have to get something done.[/quote:738fcf643a]
You could try higher octane,don't work-check the other areas that I've mentioned.
Jul 19, 2007 at 8:39 AM
