1994 Nissan Maxima problems starting it the rain
NICHOLSD
  • 1994 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 124,000 MILES
One day it was raining & the car would'nt start? When I checked the plugs they were wet with oil and smelled go gas. I wipped them off and the auto started. What could be causing this problem?
Wednesday, March 19th, 2008 AT 5:49 PM
RACI47
  • 85 POSTS
Oil on the plugs is a valve seal leak. Change the fuel filter run a additive in the fuel to clean the injectors and keep an eye on the oil level on the stick if the problem occurs again you may need to have the heads redone.
Wednesday, April 9th, 2008 AT 12:55 PM
