1993 Nissan Maxima Blower Only on High
EMAN93
I have a 93 Maxima with the auto climate control. The problem is that the blower now only works on high. It does not blow on the other 3 settings, just on high. Please help me fix.
Thanks,Eric
Aug 12, 2006 at 12:38 PM
MIKEYBDMAN
  • 623 POSTS
[quote:8882695f82="eman93"]I have a 93 Maxima with the auto climate control. The problem is that the blower now only works on high. It does not blow on the other 3 settings, just on high. Please help me fix.
Thanks,Eric[/quote:8882695f82]
Sounds like you need to replace the blower motor resistor. This is located in the ducting just downstream of the blower motor. It controls the lower speeds.
Aug 12, 2006 at 1:06 PM
EMAN93
Can you provide a more specific location. A picture would be great. Do I need to take the blower motor out to get at the resister? It's just not obvious where it is located.
Thanks,Eric
Aug 26, 2006 at 10:18 AM
AFRIDI
no.... you don't need to take the blower motor out... blower motor resistor is located right under the dashboard....
if you cant find it or don't know which one is the resistor ... let me know.. i'll email u a pic of my old resistor
i replaced resistor for my nissan sentra 1994... works great now...
Sep 2, 2006 at 5:03 AM
Suggested Repair
Replace the blower motor resistor. It is in the ducting just downstream of the blower motor, under the dashboard, and the blower motor does not need to be removed to access it.
Conversation Summary
A 1993 Nissan Maxima with automatic climate control has a blower that works only on high and not on the lower three speeds. The expert advised replacing the blower motor resistor, located in the ducting just downstream of the blower motor. Another reply confirmed the resistor is under the dashboard and that the blower motor does not need to be removed.
