1998 Nissan Maxima Blower Only on High Fix
RMAC529
I hava a 1998 Nissan Maxima. The AC/Heater blower only works on high. When on lower settings, the cool or hot air seeps out, but the fan does not blow. All fuses look good. I am assuming it is the switch. How do I access the switch?
Jul 18, 2007 at 4:19 AM
  • 75,988 POSTS
[quote:21f12dc87e="rmac529"]I hava a 1998 Nissan Maxima. The AC/Heater blower only works on high. When on lower settings, the cool or hot air seeps out, but the fan does not blow. All fuses look good. I am assuming it is the switch. How do I access the switch?[/quote:21f12dc87e]
Find the blower resistor pack and change it. and again it might be the blower motor itself. Try hot wiring it,if it comes on-change the resistor.
Jul 18, 2007 at 7:16 PM
Suggested Repair
Replace the blower resistor pack. The blower motor may also be at fault; hot-wire the motor, and if it runs, replace the resistor.
Conversation Summary
The owner of a 1998 Nissan Maxima reports the AC/heater blower only works on high; on lower settings air seeps out but the fan does not blow. Fuses look good and the owner suspects the switch. The expert advises replacing the blower resistor pack and notes the blower motor could also be the cause, suggesting a hot-wire test of the motor.
