1990 Nissan Maxima No Start
BL8DERBOY5150
  • 15 POSTS
Well i had just bought this car from someone recently. And thus far ive had a few problems.
First the battery in the car wasnt even the right one that belongs in their(boguht a new one) Then after doing that the car woudlnt start after it has been started 2 times after that. After researchiung the problem i foudn it was a bad alternator i had the guy come out take it out and go replace it *it was still under warranty* Then the car was running fine until me and my room mates took a drive across town. The car started shaking and what not and i decided to pul into a parking lot. Sure enoug after i killed the engine and tried to resatrt it, it woudl not start. We looked into the engine to find the alternaotr belt broke..... Ok no big deal cost about 10 bucks to repalce and was semi easy with a alligator grip wrench. and sometime and alot of dirt. Well its been 4 days since we repalced that and the car has been driving realy find. We went out earlier today to pick a vaccum up we got home with the car having no problems. But as i was heading out to pick someone up i tried starting the car. and nothing is hapening. The engine isnt trying to turn over or anything. The liughts all work and when i try starting it nothing dims. we lifted the hood and listened while it was trying to be started. the battery lets off kind of a hummimg/humming noise that alsts maybe about 10 seconds then stops and wont do it again until about a minute or so*when trying to start* and the right side of the engine has a clicking noise that is heard while turning the key. weve tried to start it while hitting the starter with a peicie of wood and it wont start still no turn over or anything. So if anyone who knows what the asnwer is to this can u please get back to me realy soon cause this is our only car and is much needed for work.. Thanks
Apr 4, 2007 at 2:21 PM
  • 75,988 POSTS
Sounds like a very bad connections involved here-triple check it. Start there before I get complicated.
Apr 4, 2007 at 3:06 PM
BL8DERBOY5150
  • 15 POSTS
Well im not quite sure what i should be checking this is my first car and already ive learned quite a lot just from the stuff I have had to do so far... so lol i need more of a walk threw
Apr 4, 2007 at 3:23 PM
  • 75,988 POSTS
When you turn key to start do you here the starter engaging the engine-Also when you hit the lights do they come On. And when key is in On-do you see all the idiot lites
Apr 4, 2007 at 4:02 PM
BL8DERBOY5150
  • 15 POSTS
well i hear a clicking noise when i do turn the key, and when its in the on position all the old lights are on
Apr 4, 2007 at 4:08 PM
  • 75,988 POSTS
What is this Auto or Manual Tranny?
Apr 4, 2007 at 4:30 PM
  • 75,988 POSTS
Try this-get a jumper wire put an alligator clip on it-on this end take it to the little terminal at the starter solenoid the othe end tap it to the postive terminal of the battery-did the starter kick over. If not we got a starter control circuit problem-could be a clutch switch or neutral safety switch also known as inhibitor or the ignition switch itself.
Good Luck-Man you working me but its okay this is my job helping people like you. Hmmm!!!! its getting complicated I love it-bring it On amigo. Freddy is ready lol.
Apr 4, 2007 at 4:40 PM
BL8DERBOY5150
  • 15 POSTS
Ok so although i knew nothing of what you just said i did some investigating. ANd found the starter haha. I then moved the lil rubber thing protecting the *what i think to be the postivie* connect it to the battery nothing happened. Then after i conect the other end of the jumper to the neg side i was shocked hahaha. But anyways so i removed the jumper from *what i then figured to be( the negative part of the start and connect it to the battery and it started making a whirling noise liek something inside was spinning so im gonna guess that was it kicking over. So if it kicked over what does that mean? the guy who sold me the car after i called him left me a message saying it might be the battery is no good? But if the liughts arnt diming and what not woudl that be the case? im still hearing that damn clicking noiuse coming from the other side of the engine though *not from the starter* so i dont know. As for the wiring it looked like this guy might have done it himself cause theirs electrical tape everywhere.. but i dont think its a bad connection i made sure evrything was connected and still nothing. Thanks for having patience with me i know im not exactly car savey
Apr 4, 2007 at 6:57 PM
  • 75,988 POSTS
Okay-get a wire like a speaker wire put both together end to end-now go find the starter. at the starter there's a little small terminal hook it there and take the other end tap it over the positive terminal of the battery NOTE: this should be done on a small period of time-not to long at least 2sec interval you should be hearing the starter engaging the engine. What you are doing is bypassing the starter circuit-if the starter should crank the engine with the jumper wire-your problem is one of these ignition switch/neutral safety switch or the wire itself.
With a good battery and tight connections and when key is turn to start position the engine should crank-if not then go check the ones I've listed.
In the event that you have no knowledge about electrical-I strongly recommend you take it to the pros-this is not a DIY thing I told you earlier its gonna be complicated.
Get something going and get back with me
Good Luck
Apr 4, 2007 at 7:23 PM
BL8DERBOY5150
  • 15 POSTS
Good Luck[/quote]
Ok well last time i didnt try it with the key in the on position but this time i did. I heard the starter kick over but the engine didnt crank. So then its woudl be one of the 3 u listed how would i go about checking them *again use dumb asnwer please haha
Much appreciated
Apr 4, 2007 at 7:55 PM
  • 75,988 POSTS
Now we're getting somewhere.NOTE: when the starter is kicking over and engine not turning its a sign of the overrunning clutch slipping on the starter-but 1st double check all connections to and from the starter-connections clean and tight-sorry to say the **starter** when south of the border on you.
Good luck-Amigo-laterz
Apr 4, 2007 at 10:39 PM
BL8DERBOY5150
  • 15 POSTS
gah so the asnwer is a bad starter i now haev to replace? i think thats one of the parts not under warranty /sad face
Apr 5, 2007 at 6:39 AM
  • 75,988 POSTS
Well Amigo
It pays the cost to be the boss-sorry for the bad news-
You have a Happy Easter-Good Luck
Apr 5, 2007 at 9:37 AM
BL8DERBOY5150
  • 15 POSTS
bad news...
well as it turns out its not the starter.. i took the starter out and took it to pep boys and they ran the test it passed and they ran the test 2 more times just to be sure. Aparently one of the teeth on the starters gear is chipped so they think if might be the flywheel teeth are missing in some parts which caused the starter to chip in some places. But after i looked at the flywheel teethit doesnt look like anything is missing... battery problem? even if the lights arnt dimming when it trys to start? or can it be something else besides the flywheel... cause i dont know how to replace that. i was lucky enough taking the starter out. but they wanna charge me 70 for a towing fee.. 80 to run a no start diagnostics... then ordering the part from a place cause they dont carry flywheels... then pay labor... i dont have that much money at all..... so any advice?
Apr 6, 2007 at 11:39 AM
  • 75,988 POSTS
Relax Amigo and concentrate
Okay you did an inspector gadget on the flywheel looks okay -is it bent/warped double check before you leave the flywheel now either we do or die-get another starter and go from there.
Makes sure all connections down there are nice and clean and tighter than a drum. to include the battery side.
Do you have a voltmeter?Cuz we're gonna take out this bad ghost at your command.
Happy Easter
Apr 6, 2007 at 6:57 PM
BL8DERBOY5150
  • 15 POSTS
no i dont have a voltmeter. i did check the connections and it seems likes its all tight, ill being bringing a voltmeter to it day after tomo or tomo to check the voltage on it. But the flywheel doesnt look bent or warped. i talked to my friends grandpa and hes a mechanic he said if it was the flywheel i woudl have heard it trying to spin the flywheel though if it wasnt catcxhing which isnt the case. he thinks its the battery or the connection also. so ill replacing the battery which is under warranty then checking it from their and if the wiring is corroded maybe have to buy a new set of wiring.. i guess.. but still not sure if that will be the problem illcheck the battery and the connection again and get back to you on it
Apr 7, 2007 at 7:29 PM
  • 75,988 POSTS
I asked you earlier is it an Auto or Manual tranny
Manual tranny has a starter relay its probably the one you hearing-find it and substitute it and see what happens.
Apr 7, 2007 at 10:29 PM
BL8DERBOY5150
  • 15 POSTS
ok well i took the volt meter to the battery and its reading about 12 volts exactly. but for some reason when i tried to start the engine today i didnt hear any noise not the clicking or humming or anything liek i usually do.. i will probably go to pep boys and get replacements wires for the battery to the starter just in case its corroded and is being eaten away. but now im at a lost as for it being a manual or auto its an automatic transmission
Apr 9, 2007 at 10:07 AM
  • 75,988 POSTS
My specs calls for 12.4 or better at no load test-try the CX replacement-makes sure everything is clean and tight and report back your findings.
Good luck
Apr 9, 2007 at 1:32 PM
BL8DERBOY5150
  • 15 POSTS
well i took the battery back for an exahnge but they tested and cahrged it and it came otu perfectly fine put it back in the car and still nothing.. except the clicking and what not..
Apr 9, 2007 at 4:33 PM
  • 75,988 POSTS
:ets restart
Does the lite come On when you hit the switch? and when you turn the key to start did the lite when out. if it does we're dealing with connections.
If it has a relay-put the voltmeter on the relay battery terminal/cable going to the starter.Now turn key to start, do you have voltage there-if not the relay is bad.also make sure the wire coming from the ignition switch has power when key is at start position.no power coming from the switch could mean the neutral safety switch is bad or the ignition switch itself.
If the battery and connections are good-the components left is the starter/relay/NSS/Ignition switch.
You sure the engine is not seized. check it out by turning the crankshaft over.
Apr 9, 2007 at 5:50 PM
BL8DERBOY5150
  • 15 POSTS
well lets rember who your dealing with <-- not an auto mech haha how the heck do i turn the crankshaft and what not. as for the relay i cant even find the damn thing to being with. and i woudl know were to look for the igtion crapola.... sorry im an idiot pretty much
Apr 9, 2007 at 8:15 PM
  • 75,988 POSTS
BTW I've been asking myself how the heck did you became a Tech1-you're not playing with me right!.
Anyway find the pulley where all the belts at should be at the bottom centerline with the engine there will be a bolt on the center of the pulley-use the correct size socket and attempt to turn it.
The relay should be a blue plastic square looking box-cycle the key to start a few times while listening for a click under the dash or in the engine compartment or call the dealer.
Apr 9, 2007 at 11:26 PM
BL8DERBOY5150
  • 15 POSTS
well the only thing that we ever heard clicking was a metal thing on the right side of the engine that has like 6 metal wires hanging out the top of it and i dont think thats it.. but il keep on trukcing how do i test it if its still good when i find it.
Apr 10, 2007 at 7:25 AM
  • 75,988 POSTS
There's an illustration on it showing the switch and coil side. the switch wiil read infinitive, coil continuity.
Apr 10, 2007 at 10:26 AM
BL8DERBOY5150
  • 15 POSTS
well i found the problem finally with a way of testing it my dad told me. Putting the car in neutral and trying to start it. and it worked so i guesss now i need to drop a hundred or so down on a neutral safety switch which is running about 80 so far... but thanks alot for your help and helping me learn
Apr 10, 2007 at 11:41 AM
  • 75,988 POSTS
You are most welcome its my job to help people in need here.
Apr 10, 2007 at 11:59 AM
BL8DERBOY5150
  • 15 POSTS
alright so my car has been running good for quite awhile. the only problem is still the neutral safety switch. fortuantley ive started working at pep boys like a week after my last post. so ive learned a few new things. BUT! my car runs decent but it makes a put put kinda noise when its revving up and the gas is going into the engine kinda pulsing. now the car is still in bad shape ive been slowly working on it. and i know it needs a new fuel filter. and a new fuel tank since its reading this one wayyyy wrong. but i was also told that one of my fuel injectors could be bad. and theirs a smeel of gasoline when i drive. theirs no apparent leak and its been like this for awhile. the car gets realy crappy gas mileage though, so im wondering how many different things it could be besdies the fuel lines
Jun 19, 2007 at 2:52 PM
BL8DERBOY5150
  • 15 POSTS
My radiator overheated. Ok now that big of a deal. But i put water in it. on the way home from putting the water in the car dies out on me after running very rough. Ok so the radiator was overheating again. w.e, BUT! when the car died and i pulled it over. I looked under the bottom of the car. Oil was everywhere on the car parts underneatah. And when i checked the dipstick it was completl;y empty. what do i need to do now HELP!
Jun 25, 2007 at 5:23 PM
Suggested Repair
Replace the neutral safety switch (inhibitor switch). The no-crank condition cleared when the automatic transmission was placed in Neutral, which points to that switch. Also keep battery cables and starter connections clean and tight. Later complaints about fuel pulsing, a gasoline smell, overheating, and sudden oil loss were not diagnosed in the thread.
Conversation Summary
A 1990 Nissan Maxima had repeated no-start problems after battery, alternator, and belt repairs. Lights worked and a click was heard, but the engine would not crank. Battery tests were good and the starter passed bench tests. Bypassing the starter circuit made the starter spin without turning the engine. The owner later found the car would start in Neutral, identifying a faulty neutral safety switch. Follow-up posts about rough running, poor mileage, a fuel smell, overheating, and an empty oil dipstick received no expert diagnosis.
