2001 Nissan Altima P0420 Code
JTSHONO
I have a 2001 Nissan Altima GXE (2.4) with 109,000 miles. I am receiving two error codes. One of the codes was for a misfire on 4 which was solved by replacing the intake manifold gasket. The other code was P0240. I have already replaced both O2 sensors and the catalytic converter has also been replaced. After I reset the system, the check engine light comes on again somewhere between 15-30 miles after resetting it. What else should I look for that could be causing the problem? JTSHONO@yahoo.com
Aug 5, 2007 at 3:11 PM
  • 75,988 POSTS
[quote:6179812a0c="JTSHONO"]I have a 2001 Nissan Altima GXE (2.4) with 109,000 miles. I am receiving two error codes. One of the codes was for a misfire on 4 which was solved by replacing the intake manifold gasket. The other code was P0240. I have already replaced both O2 sensors and the catalytic converter has also been replaced. After I reset the system, the check engine light comes on again somewhere between 15-30 miles after resetting it. What else should I look for that could be causing the problem? JTSHONO@yahoo.com[/quote:6179812a0c]
P0420....Catalyst System Efficiency Below Threshold (
The O2 Sensors are they OEM parts- What is the octane fuel are you using if its 89 change it. Put some fuel additives and see what happens after you reset it.
Aug 5, 2007 at 9:31 PM
Suggested Repair
Treat the code as P0420 (catalyst efficiency below threshold). Confirm the oxygen sensors are OEM parts, switch away from 89-octane fuel if that is being used, add a fuel additive, reset the system, and see whether the light returns.
Conversation Summary
The owner of a 2001 Nissan Altima GXE 2.4 with 109,000 miles fixed a cylinder 4 misfire by replacing the intake manifold gasket. A remaining code reported as P0240, identified as P0420 catalyst efficiency below threshold, returns 15-30 miles after reset even though both oxygen sensors and the catalytic converter were replaced. The expert advised checking for OEM oxygen sensors, changing from 89-octane fuel if used, adding fuel additives, and resetting the system.
