Check engine light on #4 cylinder misfire, idid change plug wire did full tune upsteel samething
Tuesday, December 16th, 2008 AT 5:50 PM
ZACKMAN
MECHANIC
I know you had replaced the plug and wire. Remove distributor cap and check if the #4 prong and the rotor are worn out or broken off. Check #4 fuel injector, and perform a compression test to ensure that cylinder 4 is not leaking.
