2001 Nissan Altima P0300 Idle Stumble
JVDUARTE
I have a 2001 Nissan Altima GXL (mileage 112,000 4cyl.) The check engine light came on and the diagnostic gave a code of P0300. Mechanics I've taken the car insist that it is a fuel injection problem. They've replaced fuel injector, but check engine light remains. The car weakens when idle as if to turn off on its own, but then goes back to normal. What do you think is the problem? I can't even afford to take it to mechanics anymore. They've even charged me for work not done.
Nov 18, 2007 at 1:07 PM
BLACKOP555
  • 10,386 POSTS
Faulty spark plugs or wires
Faulty ignition coil
Faulty oxygen sensor, unlikely but possible
Faulty fuel injector, test to see they are getting proper voltage at proper time.
Burned exhaust valve, test with compreession test.
Faulty catalytic converter, exhaust smell like bad eggs? if so replace it
Stuck/blocked EGR valve, take apart and clean, may be stuck open due to carbon build up
Faulty camshaft position sensor
those are just about all of the solutions.
if the car stumbles or hesitates when accelerating then check the sparks, wires, and dist cap & rotor first.
Nov 18, 2007 at 1:17 PM
Suggested Repair
Check spark plugs, plug wires, and the ignition coil. If the engine stumbles or hesitates while accelerating, inspect the distributor cap and rotor first. Also verify that the fuel injectors receive proper voltage at the correct time, and consider a compression test for a burned exhaust valve. Other possible causes listed are a stuck or carbon-blocked EGR valve, a faulty oxygen sensor, a failing catalytic converter, and a faulty camshaft position sensor.
Conversation Summary
The owner of a 2001 Nissan Altima with about 112,000 miles reports a P0300 code and a weak idle that nearly stalls, then recovers. Mechanics blamed the fuel injection system and replaced an injector, but the check engine light remained. The expert lists several possible causes, including spark plugs or wires, ignition coil, injector voltage and timing, a burned exhaust valve, catalytic converter, stuck EGR valve, oxygen sensor, and camshaft position sensor, and advises checking plugs, wires, and the distributor cap and rotor first if the car hesitates under acceleration.
