My car will not start
230,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
TRINITY EDWARDS
I was going down the road about forty five mph and i heard something but could not figure out what it was. then about a mile down the road i lost all power steering, all power the car shut of.. so i pulled over looked under hood and both of my belts had just came off. they did not break they just popped off. So it took about two or three hours to finally get belts back on car. i then tried to crank car back up and it threw one of the belts off again as soon as i tried to turn it over. So i had someone who i thought could fix my car and all they did and said to me is they put the belts on, but car will not crank. And that they did not know what was wrong. When i try crank the car all it does is roll over (if i am saying that right). i know when it is trying to be cranked both belts are turning. I think it could be my crank pulley because it looks like it it is moving way too much. But I do not know. i was told that it jumped time. I just do not want to believe it jumped time because of the crank pulley moving the way it does. It just seems like it would need to be replaced, but if it does do i have to get a whole crankshaft or just a pulley? what parts would i need to get? i just really need my car fixed. please help me.
Dec 8, 2017 at 6:47 PM
CARADIODOC
  • 34,415 POSTS
Based on your great observations, the best suspect is the harmonic balancer/vibration damper. The drive pulley for the belts is cast into the outer ring which is glued to the center hub. It is not unheard of for the bond to let go, then that ring slides off-center or wobbles.
Auto parts stores have large books showing nothing but these vibration dampers for almost every model and engine. There are too many to keep one of each in stock, so they will most likely have to order what you need, but that usually only takes a day or two.
Sep 29, 2020 at 4:55 AM
