Shut off at a stop sign, the engine cranks but does not start?
300,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
NONSTOP
Engine turns over but won’t fire up? I swapped out the crankshaft positioning sensor, but my car is still just cranking but not starting. It turns over just fine, but it will not start. I thought it might be the crankshaft sensor because I wasn’t getting any movement on my RPM gauge but now that I swapped it I’m still not getting movement on the RPM gauge, would you know if the camshaft sensor would keep my car from starting? It’s strange. I was just driving home came to a stop at a red light. It shut off and it hasn’t started since I pulled the fuel line off past the fuel filter and it seems to work fine when I crank the car over it has very strong pressure, I pulled out one of the plugs and grounded it and it seems to have spark. I just don’t understand what else it could be any possible way you can help me figure it out.
May 12, 2024 at 7:38 AM
  • 110,251 POSTS
If you aren't seeing an RPM signal, that is usually an indication of the crank sensor, but you already replaced it.
In this case, the first thing I need you to do is confirm there is no spark at the plugs. Take a look at this link, it explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know. Also, if you do have spark, check if the engine starts if you use starting fluid. If it does and then stalls, it is likely a fuel issue.
May 12, 2024 at 11:51 AM
  • 55,845 POSTS
Also, we should check compression, if you could upload a short video of the engine cranking over it would help us see if the engine is hurt or not.
Please go over this guide and get back to us.
May 12, 2024 at 12:18 PM
