Engine will not idle?
CHAS662
  • 7 POSTS
Put on a new ignition module. Thanks again for the help. It starts now but it runs rough and sometimes back fires. Test drive and it run so bad it would hardly go. I get code 22 for the tps but I had put a new one on already. I just took it off and used the old round bushing and put new one on. Did I need to do something else?
Thursday, February 18th, 2021 AT 12:58 PM (Merged)
HMAC300
  • 48,601 POSTS
Did you check vacuum hoses for soft and broken/cracked and for a blown gasket under tbi unit like I said in first reply
CHAS662
  • 7 POSTS
I do not find any bad vacuum hoses or leeks gasket seems to be ok also.
HMAC300
  • 48,601 POSTS
Check your firing order you may have things mixed up there.
CHAS662
  • 7 POSTS
With your help and expert advice we have old truck going down the road smooth. Makes me fell good. Thank You very much. Hope my small donation helps.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,513 POSTS
Thanks for the donation! It helps to keep the site going!
Cheers! Ken
MARSHALL
  • 1994 CHEVROLET SILVERADO
  • 6 CYL
  • MANUAL
  • 170,877 MILES
I have a 94 chevy 1500 w/t, with a 6 cyl 4.3 liter engine. It is also a 5 speed transmission. The problem that im having with my truck is that somtimes when it is warmed up or warm outside the truck trys to stall at stop lights. I have had it tuned up, filters all replaced. I have spent over $1000 trying to get this fixed and all I keep hearing is "it ran fine when we had it". Please help me.
  • 109,709 POSTS
Check for vacuum leaks. In 94 there were some problems with intake gaskets.
Let me know what you find.
MARSHALL
I didn't find any vacuum leaks. But the EGR was very dirty. So I have it siitting in carb cleaner. I Also found that I have a leak in the exhust around the Y pipe.
  • 109,709 POSTS
Let me know if the egr helps.
