My Car Won't Start After Buying New Parts For It
DXA101
  • 2004 HONDA ACCORD
  • 2.4L
  • 4 CYL
  • 218,748 MILES
One day as I was driving I came to a stop and noticed that my car started puttering pretty noticeably. I got the oil changed soon after but even after it still continued. It started to have a hard time getting the car started so I replaced the battery and had no troubles starting afterwards but it still continued to putter. Soon enough it started having a tough time catching again when I would turn the ignition so I replaced the alternator. A couple of weeks later it started having a hard time turning on again. Eventually it would not start up anymore. I figured it was the cold weather but from everything I was hearing and reading I came down to the conclusion that I would be replacing the starter at the end of it all, so I did. One day later it would not start up again. We ran a computer on it and pin pointed it down to one of the relays on the main panel underneath the dashboard. We noticed that it would not make a cranking noise as if it were to turn on, in fact it made no such noise. From the relay panel we noticed that the bottom right relay was making a grinding noise upon turning the key. I replaced the relay, re-adjusted the battery, turned the key and it cranked for one second and then died off. I tinkered around but it went to making only the grinding noise from the relay.
Saturday, January 18th, 2014 AT 1:06 PM
KHLOW2008
  • 41,814 POSTS
Seems like you have been replacing components without find the cause of the problem. Above link explains what to look for and when you find out what is missing, let us know so we can continue from there.
Monday, September 28th, 2020 AT 1:36 PM
