shuts off while i'm driving
166,000 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
SHOPGIRL63
Shuts off while i'm driving mainly if i let my foot off the gas pedal i will put it in park and it will start right back up on its on.....but it mainly shuts off if i don't have my foot on the gas i have replaced the cps...and the gas pedal but this problem still remains ....any advice would be greatly appreciated.....
Feb 14, 2015 at 6:47 AM
DR LOOT
  • 2,311 POSTS
These vehicles have a lot of problems with crankshaft position sensors which can cause no spark and common to cause this condition...Buy a can of starting fluid then next time it shuts off and wont restart right away see if it will fire off starting fluid..If not this verifies you have no spark so then replace the crankshaft position sensor. Let me know if you have any questions, thanks.
also a common problem to cause stalling at stops but allowing it to restart right away every time is a dirty throttle body. You can get some throttle body cleaner from your local parts store and use that with a rag to wipe out throttle body good..They get dirty causing poor airflow which causes the problems at idle since there isnt as much flow as when going down road...This is such a simle problem its often overlooked by shops. Let me know if you have questions, thanks.
Feb 14, 2015 at 11:46 AM
SATURNTECH9
  • 30,868 POSTS
Just to add to this one they said they already replaced the crankshaft position sensor if it restarts right away right after it stalls and runs good after that it doesnt sound like a crankshaft position sensor. Shopgirl63 ypu said you replaced the gas pedal assembly? Are you setting any codes? If so what are the exact code numbers not code descriptions?
Feb 15, 2015 at 9:46 AM
