car stalls when decelerating from high speed
2008 SATURN VUE
94,000 MILES • 4 CYL • 2WD • AUTOMATIC
RHONDAHAMLIN
when travelling at high speeds [~60mph or above] and stopping relatively quickly -- like for a stoplight -- car will often -- but not always -- stall
have not had the problem when able to coast before stopping
dealer has replaced lots of things; problem persists
Jan 28, 2014 at 2:12 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like a torque convertor issue is there any codes set in the computer?Also what has been replaced?
Jan 28, 2014 at 3:03 AM
RHONDAHAMLIN
Don't know about the codes but the following has been repaired/fixed/replaced by dealer - most under warranty:
Fuel induction service
Cleaned injectors throttle body and valves
Replaced throttle and performed idle relearn
Tune up
3-5-r wave plate broken - Replaced 3-5rev clutch housing, piston and wave plate,replaced 2-6 piston, lo reverse piston and cover, split case and replaced filter, cleaned out debris, flushed and reassembled, set to end road tested ok
Jan 29, 2014 at 12:47 AM
SATURNTECH9
  • 30,869 POSTS
If there were debris in the transmission they had to clean out of the transmission they should have replaced the torque convertor because you cant clean those.
Jan 29, 2014 at 2:39 AM
RHONDAHAMLIN
Wow - I have brought the car in at least 3 times in the past couple of months where they did nothing because they couldn't get the car to stall on their watch - I will definitely talk to them about this pronto- you are awesome - thanks!
Jan 29, 2014 at 4:27 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep me posted on what they say.Cant belive they didnt change it.
Jan 29, 2014 at 1:19 PM
