car shuts off when driving
172,000 MILES
FROGLONG
when driving for A WHILE CAR SHUTS OFF AFTER LET IT SEAT FOR A WHILE IT WILL START BACK AND AFTER DRVING IT FOR A FEW MINUTES IT WILL SHUT OFF AGAIN IS THIS THE CRANK SHAFT POSITION?
Apr 23, 2013 at 6:12 AM
JDL
  • 16,098 POSTS
Are you losing spark--fuel-- everything? The crank sensor is a possibility among others.
How long since a tune-up? Can you check for applicable trouble codes? To check for codes, at the least, you need an obd2 code reader. Your local autostore should have a code reader.
Apr 23, 2013 at 6:32 AM
FROGLONG
had codes checked and it showed code for crankshaft position sensor changed it and check engine light went off
Apr 24, 2013 at 6:58 AM
JDL
  • 16,098 POSTS
I hope you got it fixed by now? goodluck
Jun 27, 2015 at 2:50 AM
