1996 Mitsubishi Eclipse Top End Knock
MITSUBISHI
ITZAMITZ
I have a '96 eclipse rs 2.0L, manual,147,000m with a loud top end knock it also smokes perfusly from the exhaust the smoke is light grey. what could be wrong? Also is the 4g63t (eclipse gs-t motor) a direct bolt on to my rs? im thinking of doing a swap. -greg
Oct 12, 2007 at 12:54 AM
  • 75,988 POSTS
The valvetrain has failed-You need a valve job and close order inspection of the liters/followers/camshaft.
Oct 12, 2007 at 10:16 AM
Suggested Repair
The valvetrain has failed. Perform a valve job and closely inspect the lifters, followers, and camshaft.
Conversation Summary
The owner of a 1996 Mitsubishi Eclipse RS 2.0L reports a loud top-end knock and heavy light-grey exhaust smoke, and asks whether a 4G63T GS-T engine is a direct bolt-in swap. The expert says the valvetrain has failed and recommends a valve job plus close inspection of the lifters, followers, and camshaft.
