2001 Mitsubishi Eclipse Stalls After Battery
MITSUBISHI
THEMAN97
My name is Rickey and I have a 2001 eclipse spyder, 4 cylinder, and 68,999 mile on it.
Well I went to my car to start it up, it won’t crank. So I went under the hood and twisted the car Terminal connector. The crank right up. Well I was driving down the road and hit a red light, the slowly stop. So I put it in park and crank it back up, soon as I put it in drive it felt like it was going to cut off until I put my foot on the gas peddle. I change both the car Terminal connector. Still not acting right, I think this started when I recharge the battery a while back. It started acting like this when put the battery in the car after I recharge it, but it went away and I didn’t think anything of it. I just don’t know what to do, can you help me
Aug 16, 2007 at 3:51 PM
  • 75,988 POSTS
[quote:a8f0216327="theman97"]My name is Rickey and I have a 2001 eclipse spyder, 4 cylinder, and 68,999 mile on it.
Well I went to my car to start it up, it won’t crank. So I went under the hood and twisted the car Terminal connector. The crank right up. Well I was driving down the road and hit a red light, the slowly stop. So I put it in park and crank it back up, soon as I put it in drive it felt like it was going to cut off until I put my foot on the gas peddle. I change both the car Terminal connector. Still not acting right, I think this started when I recharge the battery a while back. It started acting like this when put the battery in the car after I recharge it, but it went away and I didn’t think anything of it. I just don’t know what to do, can you help me[/quote:a8f0216327]
What liter engine is this
You sounded like it needs a computer relearning-
Aug 16, 2007 at 7:58 PM
THEMAN97
[quote:78190356a4="rasmataz"][quote:78190356a4="theman97"]My name is Rickey and I have a 2001 eclipse spyder, 4 cylinder, and 68,999 mile on it.
Well I went to my car to start it up, it won’t crank. So I went under the hood and twisted the car Terminal connector. The crank right up. Well I was driving down the road and hit a red light, the slowly stop. So I put it in park and crank it back up, soon as I put it in drive it felt like it was going to cut off until I put my foot on the gas peddle. I change both the car Terminal connector. Still not acting right, I think this started when I recharge the battery a while back. It started acting like this when put the battery in the car after I recharge it, but it went away and I didn’t think anything of it. I just don’t know what to do, can you help me[/quote:78190356a4]
You sounded like it needs a computer relearning-[/quote:78190356a4]
Well its a 2.4 liter, I'm sorry, I'm new to this so whats a computer relearning and how do I check, because I don't have problem drive.
Aug 17, 2007 at 12:13 AM
  • 75,988 POSTS
[quote:d9d7dcb800="theman97"][quote:d9d7dcb800="rasmataz"][quote:d9d7dcb800="theman97"]My name is Rickey and I have a 2001 eclipse spyder, 4 cylinder, and 68,999 mile on it.
Well I went to my car to start it up, it won’t crank. So I went under the hood and twisted the car Terminal connector. The crank right up. Well I was driving down the road and hit a red light, the slowly stop. So I put it in park and crank it back up, soon as I put it in drive it felt like it was going to cut off until I put my foot on the gas peddle. I change both the car Terminal connector. Still not acting right, I think this started when I recharge the battery a while back. It started acting like this when put the battery in the car after I recharge it, but it went away and I didn’t think anything of it. I just don’t know what to do, can you help me[/quote:d9d7dcb800]
You sounded like it needs a computer relearning-[/quote:d9d7dcb800]
Well its a 2.4 liter, I'm sorry, I'm new to this so whats a computer relearning and how do I check, because I don't have problem drive.[/quote:d9d7dcb800]
Try this:
Set parking brake, start engine in "P" or "N" position.
Warm-up vehicle to normal operating temperature or until cooling fan cycles.
Allow vehicle to idle for one minute in "N" position. Select "D" and allow engine to idle for one minute.
Accelerate at normal throttle position (20-50%) until vehicle shifts into top gear.
Cruise at light to medium throttle.
Decelerate to a stop, allowing vehicle to downshift, and use brakes normally.
Process may be repeated as necessary.
Aug 17, 2007 at 1:24 AM
THEMAN97
[quote:aa7d5e1a8e="rasmataz"][quote:aa7d5e1a8e="theman97"][quote:aa7d5e1a8e="rasmataz"][quote:aa7d5e1a8e="theman97"]My name is Rickey and I have a 2001 eclipse spyder, 4 cylinder, and 68,999 mile on it.
Well I went to my car to start it up, it won’t crank. So I went under the hood and twisted the car Terminal connector. The crank right up. Well I was driving down the road and hit a red light, the slowly stop. So I put it in park and crank it back up, soon as I put it in drive it felt like it was going to cut off until I put my foot on the gas peddle. I change both the car Terminal connector. Still not acting right, I think this started when I recharge the battery a while back. It started acting like this when put the battery in the car after I recharge it, but it went away and I didn’t think anything of it. I just don’t know what to do, can you help me[/quote:aa7d5e1a8e]
You sounded like it needs a computer relearning-[/quote:aa7d5e1a8e]
Well its a 2.4 liter, I'm sorry, I'm new to this so whats a computer relearning and how do I check, because I don't have problem drive.[/quote:aa7d5e1a8e]
Try this:
It work thank for your help. I learn something new today thank you
Process may be repeated as necessary.[/quote:aa7d5e1a8e]
Aug 17, 2007 at 2:08 AM
  • 75,988 POSTS
Next time find a way to power it before you take the battery out-be jumping it while removing it-
In 2carpros you get to learn something new from the moderator's and technicians we're the world's finest auto website.
Good Luck and come again
Aug 17, 2007 at 8:59 AM
Suggested Repair
After the battery was disconnected, perform the idle and drive computer relearn: warm the engine, idle in Neutral then Drive, accelerate normally into top gear, cruise, and stop so it downshifts. Repeat if needed. Next time, keep the system powered by jumping the battery before removing it.
Conversation Summary
A 2001 Mitsubishi Eclipse Spyder 2.4L with about 69,000 miles would not crank until a battery terminal was twisted, then stalled at a light and nearly died when shifted into Drive. The owner replaced both battery terminals and linked the issue to a recent battery recharge. The expert recommended a computer relearn drive cycle, which the owner said resolved the problem, and advised maintaining power before future battery removal.
