1990 Plymouth Laser White Smoke After Heads
Ive been having trouble figuring out wha is wrong with my laser. First I broke the timing belt, bent some valves. Got it replaced all new gaskets and such. drove it for about 1 week no problems at all, then all of a sudden white smoke comimmg from under hood, from exhaust, every where. What is wrong??? I have heard that when you replace heads, you also need to buy new head bolts because they stretch ouer time.Is that true? do you think this is my problem?
Feb 15, 2006 at 9:00 PM
When replacing a lot of later model cylinder head new bolts are required as they are designed to stretch to lock themselves in place. If you did not do this and did not use a torque angle wrench then it is possible the head gasket is leaking.
Feb 16, 2006 at 12:58 AM
so do you think if I replace the head gasket and get new bolts my problem should be fixed? I sure hope so, I havent been able to drive my car for a couple of months. I'm readyto get back behind the wheel. I love that car.thank you :
Feb 16, 2006 at 5:49 PM
Do a compression test first to be sure. If you do repace the gasket again follow the manual exactly.
Feb 17, 2006 at 1:37 AM
🔧 Tools & Auto Repair Parts
Find automotive tools, diagnostic equipment, and replacement
parts for your next repair.
Shop on Amazon →
Suggested Repair
Perform a compression test before another teardown. If the head gasket is leaking, replace it with new stretch-type head bolts and follow the service manual torque and torque-angle procedure exactly.
Conversation Summary
After a timing-belt failure bent valves, the owner replaced the cylinder heads and gaskets on a 1990 Plymouth Laser. It ran for about a week, then white smoke appeared from under the hood and the exhaust. The owner asked whether reused head bolts that stretch could be the cause. The expert said later-model head bolts are designed to stretch and that skipping new bolts and a torque-angle procedure can let the head gasket leak. They advised a compression test first and, if the gasket is replaced again, following the manual exactly.
