1997 Ford Taurus White Smoke No Start
LAMFAM126
FORD TAURUS GL 110,000 TRIED THE FUEL PUMP WAS TOLD SENSOR CRANK SOUND RIGHT TO ANYONE?????????? THE CAR STARTS WHEN IT WANTS TO I CAN DRIVE IT ALL DAY AND THEN NOTHING IT TRYS TO TURN OVER BUT NOTHING THE COIL WAS ALSO REPLACED THE CAR SITS FOR 2 YRS NOW AND TAKES A LONG TIME TO TURN OVER IF YOU CAN GET TO IT ALSO BLOWS OUT ALOT OF WHITE SMOKE AND BOGS DOWN IF YOU DONT KEEP YOUR FOOT ON THE GAS
Mar 25, 2006 at 12:38 AM
LOVESCARS
  • 359 POSTS
If it's blowing white smoke you likely have a blown head gasket this would certainly cause starting problems. Pull the spark plugs and check for any coolant on the electrodes.
Look under the oil filler cap and if there is white matter this indicates water in the oil which would verify.
Mar 25, 2006 at 1:18 PM
Suggested Repair
White smoke and hard starting may indicate a blown head gasket. Pull the spark plugs and check the electrodes for coolant, and look under the oil filler cap for white residue that would indicate water in the oil.
Conversation Summary
A 1997 Ford Taurus GL with 110,000 miles starts only intermittently, cranks without starting after sitting, blows a lot of white smoke, and bogs unless the throttle is held. The coil was replaced and the fuel pump was already tried. The expert said white smoke points to a likely blown head gasket and advised checking the spark plugs for coolant and the oil filler cap for white residue confirming water in the oil.
