1990 Plymouth Laser White Smoke
KERRY JOHN
I recently replaced the heads and got a valve job on my 1990 plymouth laser. It ran great for aprox. 1 week. then all of a sudden white smaoke come from everywher, under hood, out the exaust. tons of white smoke. so I immeadtly stop driving, I'm sure I dodn not drive it far enought o get it hot. anyway the question I am asking is I have heard the when replcaing the head gasket, replacing the head bolts is a good idea, because they get streched out over the years, is that true? should I replace them.The car is 15 years old after all but, it will be well over $100 to do so. Do you think this is my problem? the car ran fine for a week before it started doing this> please please help///
Feb 15, 2006 at 10:48 PM
BIGHEAD1121
had the same problem w/an eclipse,someone said about the head bolts to me too but i had a friend look at it and it was my injectors too expensive for what i had in the car so its sitting in the scrapyard
Feb 15, 2006 at 11:22 PM
JPAM
  • 307 POSTS
yes what u are beening told is true.. those old stretch bolts cant pull the head down tight enough to get a good seal.. causeing the new gasket u just bought to blow out.. so save ur self another headache and buy some new head bolts & gasket and follow the specified torquing sequence for that car... Make sure u check oil to to make sure that no antifreeze got mixed in.... Hope that answers ur ??
Jess S.
Feb 22, 2006 at 4:48 PM
Suggested Repair
Replace the stretch-style head bolts and head gasket, follow the specified torque sequence, and check the oil for antifreeze contamination.
Conversation Summary
The owner of a 1990 Plymouth Laser replaced the heads and had a valve job. The car ran well for about a week, then suddenly produced heavy white smoke from under the hood and the exhaust. The owner asked whether aged stretch head bolts should be replaced with the gasket. Another owner mentioned a similar Eclipse problem that was attributed to injectors and was not repaired. The expert said old stretch bolts cannot clamp the head tightly enough and can cause a new gasket to fail, and advised new head bolts and a gasket, the correct torque sequence, and an oil check for coolant mixing.
