Well I can say this there is only a few things in the blower motor circuit, working backwards the blower motor itself, the blower motor resistor in the glove box on the left side has a 4 wire connector , the fan switch, a relay and a fuse, if you have no fan at all usually the blower motor the relay or the fuse is bad, if you have one or two speeds the resistor is bad, I cant figure out for the life of me why there is no relay box where it should be, I know there is one in the engine compartment, its gotta be somewhere there, my software may be wrong, I dont know
a quick test for the blower motor itself is to unplug it and run a hot wire from the battery to the blower to see if it works
Friday, February 23rd, 2007 AT 3:24 PM
