2003 Mitsubishi Lancer Spoiler Cracks
MITSUBISHI
MEGZ
Hey everyone,
just found this forum whilst surfing the net and thought id ask a quick question. I own a mitsubishi lancer gli vrx 2003 model which has been done up. ie turbo charged, lowered, evo 7 fibreglass body kit etc. unfortunately i was involved in a bit of a cscrape the other day and i now have a series of rather nasty stress fractures on my front spoiler which is painted black and is made of fibreglass. I was just wondering, what exactly is a stress fracture (ie what exactly have i done to my car and how seroius is it) and also whether it can be repaired (and stay fixed) or whether ill have to get a whole new spoiler to get it back to its original condition. thanks everyone.
megan
Dec 10, 2006 at 7:46 PM
BRUCE HUNT
  • 3,754 POSTS
I would guess that is depends on the depth of the stress fractures. Is the spoiler metal based with fiberglass exterior or all fiberglass? Reason I ask is that if it has a metal core and it is cracked you would probably need to either fix the crack with a weld or a braze.
My uncle has dealt with fiberglass repairs his entire life and I have picked up on a number of things from him. The fiberglass is very repairable but you and looking at doing more than filling a number of crack in. You would need to grind out a big area around the cracking, reinforce with a screening and then repair with a fiberglass filler. Highly doable project, rather inexpensive but the result would need to be painted.
Dec 11, 2006 at 12:31 AM
MEGZ
ahh ok thanks :) the spoiler is just fibreglass, no metal im pretty sure. would i need to go to a special firbeglass worker or would a regular panel beater do?
Dec 11, 2006 at 4:23 PM
Suggested Repair
For an all-fiberglass spoiler, grind out a wide area around the cracks, reinforce with screening, repair with fiberglass filler, and repaint. A body shop experienced with fiberglass can typically do this relatively inexpensive repair.
Conversation Summary
The owner of a modified 2003 Mitsubishi Lancer asked about stress fractures in a painted fiberglass front spoiler after a scrape and whether it could be repaired. The expert said repair depends on crack depth and construction; with no metal core, fiberglass can be repaired by grinding out the cracked area, reinforcing it with screening, applying fiberglass filler, and painting. The owner confirmed the spoiler is fiberglass only and asked whether a specialist or regular panel beater should do the work, but that follow-up was not answered.
