Power window problem
MITSUBISHI
GWTHOMPSON
2002 Mitsubishi Eclipse
76000 miles
6 cyl, 3.0 L
Power windows and moon roof have worked intermittently. The passenger side window has stopped working and will not close using either control (driver or passenger). Afraid to try the others now in case they quit. Could this be a fuse problem since only one is not working?
Thanks for your reply and help.
May 30, 2007 at 3:01 PM
JAVA MOTORSPORTS
  • 52 POSTS
More often than not it is the PWM "power window motor" that quits working. However some times a connector will come off look at your fuse & connectors first then check you motor.
Anytime you work on some thing look at the easy stuff first.
May 31, 2007 at 3:01 AM
