2000 Mitsubishi Montero Sport P0421
1942 MITSUBISHI
QUINNY24
I have a 2000 Montero Sport. Got code PO421 and have sequentially replaced all 4 O2 sensors in addition to having a complete tuneup including a new timing belt. After replacing the 4th and final O2 sensor I thought all was well but 2 weeks later the same code reared its ugly head. where do I look from here, could it be my cat? The car seems to run just fine.
Dec 15, 2006 at 11:31 AM
CARUNDELL
  • 602 POSTS
[quote:3fee5b00b0="quinny24"]I have a 2000 Montero Sport. Got code PO421 and have sequentially replaced all 4 O2 sensors in addition to having a complete tuneup including a new timing belt. After replacing the 4th and final O2 sensor I thought all was well but 2 weeks later the same code reared its ugly head. where do I look from here, could it be my cat? The car seems to run just fine.[/quote:3fee5b00b0]
Hey Quinny,
p0421 is a catalytic converter efficiency code and since you have already replaced the 2 post cat O2's then it sounds like you have a cat that has failed. Which bank is it?
Chris
Dec 15, 2006 at 8:35 PM
QUINNY24
PO421 is bank 1. How many cats are there on this thing two or three?
I wonder how long I have til it goes bad on me.
Dec 16, 2006 at 5:06 AM
QUINNY24
what is the difference between this code and PO420?
PO421 says "warmup catalyst efficiency below threshold (bank 1)" and
PO420 says"catalyst system efficiency below threshold (bank 1)"?????
Jan 25, 2007 at 6:05 AM
QUINNY24
Just for everyones info. I ended up taking my Montero Sport to Meineke and was told I needed a new cat., the owner of Meineke told me a direct fit would be $900 plus but that he could find one for much less than that probably even half. well after searching for 2 days he calls and tells me he can't get an aftermarket direct fit and I need to get it from the dealer for the original estimate of $900 plus.
I am starting to get very bitter at this thing, for one thing I bought a car with California emissions (who ever checks for that when they go out to buy a car in Pennsylvania). Well at 44 I'm still living and learning LOL
Feb 14, 2007 at 2:39 AM
Suggested Repair
P0421 indicates bank 1 catalyst efficiency below threshold during warmup. With all four oxygen sensors already replaced, have the bank 1 catalytic converter tested and replace it if it has failed.
Conversation Summary
A 2000 Mitsubishi Montero Sport set P0421 after all four oxygen sensors and a tune-up were replaced. The expert identified it as a catalytic converter efficiency code and said a failed bank 1 converter was likely. A shop later confirmed a new catalytic converter was needed, with a dealer direct-fit part estimated around $900.
