2002 Mitsubishi Montero Sport Squeak
With out seeing the parts, it's hard to say.but as far as the belts go, new belts will streach a little after the first week or so, and may require re tensioning, then they are normaly trouble fee. If the belts have been over tensioned you do run the chanch of destroying bearings on which ever acc it is driving. Automatic adjusters don't have this problem. So make sure that your servive centre is not overtightening the belts, It's your car, you pay the bill, so don't be scared to ask.
Good luck,
Mark (mhpautos)
Suggested Repair
Recheck accessory-belt tension after the new belts have stretched, and confirm the shop is not overtightening them. Overtight belts can damage accessory bearings; automatic tensioners are less prone to this. Do not replace the alternator tensioner, pulley, or power-steering pump without inspecting the parts.
Conversation Summary
The owner of a 2002 Mitsubishi Montero Sport reported a squeak under the hood that continued after the timing belt, tensioner, drive belts, AC and power-steering belts, and rear cam seals were replaced, followed by replacement of a defective power-steering belt and a transmission flush. They asked whether the alternator belt tensioner, pulley, or power-steering pump needed replacement. The expert said new belts can stretch and require retensioning, while overtightened belts can damage bearings, so the shop should be asked not to overtighten them.
