2003 Mitsubishi Montero Sport Drift
MITSUBISHI
YURIH13
I have 03 mitsubishi montero sport 29000miles, (i think the engine size is v6?), and was hit by another SUV on the front left side by left front wheel. The damage seemed minimal to front bumpers, and hood, and realignment and etc, but ever since the accident, my car drifts to the right especially on a freeway when the speed is over 50mph, and steering wheel shakes a bit on a freeway as well. Both problem is more salient when the speed is over 50mph, but drifting is there even if i'm driving in the city slow. I also noticed that when I try to make a sharp left turn, it has a resistance (more difficult to steer), and I don't experience the same resistance on the sharp right turn. The car has been repaired and alightment was checked twice, but it is within the range. If you have any suggestion to what might be a problem, please help me understand what's going on.
Thak you! :wink:
Jan 22, 2007 at 11:44 AM
SERVICE WRITER
  • 9,123 POSTS
You might have a tire problem. Try rotating the front two tires side to side and see if the symptoms change. A bad tire can give the symptoms you describe regarding the shaking and pulling. By swapping them side to side, you will see an opposite reaction. While the wheels are off have the balance checked and have the rims checked for any bend in them.
Jan 22, 2007 at 12:08 PM
Suggested Repair
Swap the front tires side to side to see if the pull and shake reverse. While the wheels are off, check tire balance and inspect the rims for bends.
Conversation Summary
A 2003 Mitsubishi Montero Sport drifts right and the steering wheel shakes, especially above 50 mph, after a front-left impact. Sharp left turns also feel resistant, and two alignments were within range. The expert suggests a tire or rim issue and recommends swapping the front tires side to side, then checking balance and looking for bent rims.
