2002 Mitsubishi Lancer ABS Install
MITSUBISHI
HOLSTERGIRL
Hi, I'm after information about installing ABS to a 02 Lancer VR-X CG. What list of components would I need & what parts already on the car would need to be changed to accommodate it? Thanks
May 12, 2006 at 10:32 PM
LOSONE
  • 1,616 POSTS
Your VR-X is kind of a mixture of cars both from Japan and Australia. The only way to ecomonically install ABS is to buy a wrecked car with your basic drive line. I think a Mirage would fit.
It will require a complete brake system, axles, wiring harness and ABS computer. It will probably cost at least $4,000 for the job unless you have a like model to take parts. Then you are looking at at least $2,000 labor. Good luck
May 13, 2006 at 6:25 AM
Suggested Repair
The practical way to add ABS is to use a wrecked donor with the same basic driveline; a Mirage may fit. Plan on a complete brake system, axles, wiring harness, and ABS computer, with substantial parts and labor cost unless matching donor parts are available.
Conversation Summary
The owner asked which components are needed to install ABS on a 2002 Mitsubishi Lancer VR-X CG and which existing parts would have to change. The expert said the economical approach is a wrecked donor with the same basic driveline, possibly a Mirage, requiring a complete brake system, axles, wiring harness, and ABS computer, at significant cost.
